Radar cruise control question
Abbotsford
I have a Canadian spec 2008 LX570 and it has the radar cruise system. We've had a few vehicles in the past that had similar systems; but not the same as this.
The cruise control only works in 5km increments. IE I can initially set it at any speed, however when I go to accelerate/decelerate using the hand controls it only goes in 5km segments. This is super annoying, I've never seen another system like this even from Toyota - and I've owned many of them... Thoughts on this? Is there a way to change it?
Yes, agree. Super annoying!
I’ve looked for ways to solve this, but I’ve not found anything in the menus or in Carista. Maybe techstream has a way, but someone else with access to that could post up.
On the bright side, KM are about a third of mph relative to their increments - so the resolution you have is much better than MPH fwiw.
No way to change that I know of, other than disabling the radar cruise and reverting to dumb cruise. Then it will allow 1km/mph increments.
After turning cruise on, push the stalk forward for a few seconds to disable radar. I now do this automatically.
Does that disable work on newer lc? The radar gets a fine layer of slush on it and disables my cruise control quite often in the winter.
Edit: just tried it, does not seem to work.
on the 2016+ , hold the button that enables cruise for a few seconds. that will enable dumb cruise control.
That worked thank you! I've read my manual cover to cover, not sure if I missed that. I was specifically looking for it.
Thanks for that info - yes this seems to disable it... I just tried it.... As I live in Canada, it's made the increments in 2km/hr segments (not 1 like most of my other vehicles) - so still better than the 5. The other frustrating thing is the force by which the system accelerates. Is there a way to allow a more gradual acceleration while using Radar Cruise? In our other vehicles with similar systems the acceleration curve was far more muted and much nicer - our Lexus is brute (almost full throttle) acceleration which is a bit un-nerving and also seems unnecessary - even excess fuel consumption etc.
I don’t know if any ability to modify cruise throttle profile.. would be nice.
Guess she just has too much power?
