Hi All -
Truck has been running great... started her up today and saw a bit of a leak that I thought was just the petcock needing to be tightened. After crawling under the rig, it looks like the radiator is leaking where the fins join the bottom of the tank.
I'm wondering if I can just drain the radiator and replace or do I need to drain the block as well? FWIW, I recently did a comprehensive flush of the cooling system so it's pretty clean.
Thanks
Thanks
