Rack paint
So I've been busy building the "J-moose" rack the last few days. And I've gotten to the point that I'm ready to paint. It's a 4wheeler rank so it is aluminum. I was jut wondering if anyone has any advice on how to paint and what to use. Thanks for the help
I used rustoleum spray paint. It has held up pretty good. It does scratch down to metal if I abuse it. But I figure I can always touch it up. Make sure to prime.
Some self etching primer from a rattle can, the Rustoleum stuff works. Then mix up some tractor paint and put it through a cheap HVLP from harbor freight.
http://www.tractorsupply.com/tsc/product/majic-all-purpose-enamel-oil-base-gloss-1-qt-matte-black
It's pretty cheap and fairly durable. Available in a few colors and you can add a hardener (also available from TSC) to it for a tougher finish, which you can't do with rattle can stuff. Sprays pretty good with a cheap HVLP on almost any compressor just regulate down to 45 psi and work up if isn't spraying well. If you want something nicer, not sure.
If you have even a small 6gal pancake compressor you could spray bedliner. I shot some Al's Liner on a drawer build with one of those and a harbor freight gun. Iit was easy and that stuff is like armor.
I have looked into it. Just trying to get it done. Tired of working on it and I dont know if there are any places around here that have bed liner in stock
