Rack Bar Mounting system for CarTopTent
e9999
Gotta get out there...
Moderator
US
has bar spacers for load distribution (thickness matched to location - done by planing)
also spacers inside brackets to prevent motion front and back
bolted down with 5/16" bolts to prevent side and up/down motion
1"x2" steel tube extending out to be bolted on trailer or roof rack.
extension also acts as support for opened half base
added: if anybody cares, the spacers are made out of 1/4" stock. They can be used pretty much as is in the center sections, but have to be thinned considerably between the brackets and the edge of the tent. The frame is not perfectly flat so the gaps vary depending on where it is...
looking pretty good
I've been trying to come up with a better mounting system for my rack/tent.... I think you may be on to something there
did about 25 miles of very rough road, could not go faster than 5 mph.
Had the CTT on a trailer. Was bouncing around like crazy (the trailer)...
No indication of looseness so far. Seems rock solid.
