phxtlc said:2. MAX doesn't blow as cold as 2 or 3.
medtro said:At MAX, air goes through the evaporator the fastest, and has less "cooling" time. Air is cool better at 2 & 3, but the rear passengers may not like the fan at 2 & 3.
RavenTai said:I have noticed the same thing on my R134a Auto AC 80, when it first turns on and the computer is trying to cool off the hot cab with the fan on high the air coming out is cool but not ice cold, later on when the cab cools down and the fan slows the air coming out is ice cold and chills you to the bone, I dislike recirc and try to use fresh all the time so incoming air temps is not the reason,
in theory the orifice valve should adjust to maintain evaporator ~35 degree no matter how much air flows through it, but I have never been in a new 80 so I do not know what its peak performance is, maybe it is just overwhelmed or maybe it cannot keep up because the refrigerant is low, I have not yet checked the pressures as it has stayed about the same coming up on the third summer with my 80.
I have a thermometer I need to put in the vent.
phxtlc said:Out here we have to use Recirc or we'll fry, not to mention the constant beach worth of dust and sand flying around. It's amazing what a difference the Sun makes. I never had such an issue when we lived in Atlanta, but then again it was never 110 degrees. I wouldn't mind trying to design some type of cabin filter to retro into the truck. Hmmmm
