Quick Stuck E-Brake Question
Lee, New Hampshire
Website
www.joshua-jones.com
I have seen all the posts about adjusting the E-brake, and it looks as though I am going to need to head in that direction soon. But,
I just pulled up good on the e-brake, and it took untill the very top to hold the truck, so adjustment is needed. Now there is no response when the handle is lowered, so my cable is stuck. Can I go under and pull the cable to release them (I had a truck I could do this with) so I can get home without roasting my brakes?
Thanks,
Josh
Looking at the ebrake repair thread you can see where the cam arm goes through the dust shield. You can pound that free with a hammer or similar. That is what I did and I didn't burn up the brakes. You can just climb under and see where the cables go but I found that it took more than pulling to free them up.
I am doing my e-brake monday or tuesday. Seems this is a popular issue lately.
Good luck
John
First you shouldn't drive the truck until the e-brake is fixed. Unlike the trucks with rear disk brakes where it has separate shoes for the e-brake your truck uses the rear shoes for both purposes.
This is quite common on Toyotas and I've dealt with it several times. I live about 45 minutes away in Groveland MA and have some time tomorrow late morning early afternoon where I could stop by and point you in the right direction if you would like.
Thanks for the offer, but I am busy tomorrow. I guess the 80 will sit here for a while.
I just looked and is it most definitely drums, so the cable pulls the shoes against the drum. I get that but, if I can get the cable and arm free the hydraulic brake portion will still function correctly, will it not?
the problem is with the bellcranks. If you look where the cable attaches to the arm at the backing plate you'll notice that it has a rubber bumper on it. With the e-brake in the off position those bumpers should be touching the plate. They won't be, so smack them with a hammer or other heavy blunt object until they are. Then don't use the e-brake until you fix it.
Just a few light taps and it was free (only the driver side was stuck) cable is working fine, can these things ever be cleaned lubricated, or is it just best to replace??
At this age I always replace and I do both sides and be done with it. I get a bellcrank, BC mount, internal cable and all new pins and clips. When I reassemble I pack the mount boot with white lithium and lubricate everything else with it as well.
I did my 96 at around 80k and it's now at 210k and it's been fine.
my 62 had a similar mechanism and I tried to clean it, sand blast, lube it etc, ( I was really broke at the time), still then froze up fairly quickly.
I have all the parts from Mr Toyota and will be going that route and think it probably is best.
Good luck
John
Which parts are needed to do the repair correctly?? I would like to have them in hand before ripping apart the drums.
I'm reincarnating this dead thread. I have a 93' with rear discs, and I started driving it after it sat for about 2 months. I heard a scraping coming from the rear wheel(s?) which I assumed was snow or ice in my wheel. Well, it got hot today and the scraping did not go away. I tried the e brake while going about 10mph and no braking power at all. Are my rear drums stuck? And are they burned out?
