Quick release PUMA mounting advice..
NYC / CT
okay I've searched the forums, so far did not find what I was looking for.
Has anyone worked with quick release pins and anchors before? I've got a sweet set of @scrowley drawers (wood) and I'd like to mount my PUMA on top of the left wing with a quick release so I can pop it off when I want to sleep in that space, move the PUMA to behind the front seats. Like 4 quick release pins with handles that pop into anchors - just press the button on top to pop them off. I know there is the perfect setup out there, but have been searching for a while on 'Mud and Google with no luck.
This is the closest example I found of what I'm looking for, but they're pricey so want to be sure before ordering anything: http://www.amazonsupply.com/stainless-quick-release-cadmium-plated-locking/dp/B00DC5OQLE
Any craftsmen out there with experience with these sorts of things?
Thank you in advance, 'Mud!
J
I just recently used these. I used a couple of fender washers, drilled out the holes on the bottom of the Puma (3/8" bit), and used the rubber feet to make bushings. I used to have it bolted to my box, but wanted to be able to remove it quickly. I can have it out in less than a minute. It's very stable, with almost no movement.
Awesome. Great idea! Are those pins sturdy enough for a crash or a roll? That's my concern in addition to convenience.
And have you got a link to them?
Thanks!
J
Sent from my SGH-M919
I think the pins are pretty sturdy. I'm more concerned about my box shifting in the truck during a roll than the compressor coming off of my box.
I don't have a link to the pins. @LandCruiserPhil came up with the idea to use them when we were discussing this problem.
The same pins we used in our sway bar disconnects in the beginning, now we use SS. As for sturdy, the wood in Otters case would be the weak point. I have a box of them (non SS) with hair pin clips if you dont want to spend the time looking.
Pins are steel 3/8" dia with a usable length of 2" Clips are 1/8"
Thank you @Otter and @LandCruiserPhil. This sounds like a good solution.
LCP since you use these do you sell the hardware, or can you drop a link to it?
LCP I might also grab some sway bar disconnects are those each end or front and rear (if there is a rear)?
J
J
I now buy all my hardware in bulk but you can find it at most hardware stores.
Disconnect are only available for the front from us. Our testing has found only more activity with the rear disconnected and zero gain in flex. The balance with the front disconnected and the connected seems to work the best off road.
For you;) buy a set of disconnects and I will include the Otter set (4-clevis pins and 4-1/8 clips) for an additional $10 and you qualify for a free console organizer :smokin:
Bam - it's a deal. Let me know how to set that up - will take organizer in black if that's an option.
Thanks!
James
payment sent, along with shipping address. thank you LCP!
ok I have a safety idea for the PUMA - I'm thinking of using the 3rd row wheel well seat bolt along with a climbing bolt hanger, then using some webbing to attach with carabiner to the pump. I just don't want the PUMA flying past the 2nd row in the event of an accident or roll.
Anyone know the diameter of the 3rd row seat bolts?
8mm
Shipped today
Thanks for the order:cool:
