Degnol said:They are full manifold vacuum, like where you would hook up a vacuum gauge or an accessory that requires constant vacuum. Different than ported vacuum used to advance the diz. I don't mean to be too elementary, but just wanted to clarify.
GL
Ed
GreenWeeny78 said:My current vacuum line still has full manifold vacuum, but my thinking and I talked to James at Over The Hill 4x4 about it. Is that it is not pulling enough vacuum to open up the diaphram in the fuel lock valve enough. So I need more volume to pull it open when at higher speeds.
