Quick one: knock sensor wire
Lakewood, Ohio
so long story short I've been bandaiding a broken knock sensor connector and it's been throwing code 52 (rear knock sensor) more often than usual. So I ordered up a replacement connector/whip:
It looks like the only option here is to cut the connector on the right leaving just the block connector and a bit of wire. Then cut the old broken connector off and solder in the new.
I'm prepared to do this but am not sure if this is the best course of action.
What's the preferred method given the wire pictured above?
You can't just replace that section of harness with the new one?
Didn't seem long enough/ didn't see a plug for it.
While this is a toyota part it's not specific to my 80
Yeah I would mark then pull all the pin terminals and just rebuild it from scratch. Since I have everything I need it's about a 10min job.
When i was replacing my rear knock sensor lead, the parts guy told me that the connector alone isn't available for him to order for me.
Also that a bare pigtail with the connector and a wire lead was not available to order.
So the pictured cable is what i used, and i cut and soldered because the plastic of my connector was badly degraded.
It's a 1-pin connector, so it would be a quick job to use just a new connector on the existing wire - if you could buy one.
I guess the contacts they use inside the plugs are probably available to buy. But it appears at the moment that if you go to a toyota dealer, this is the cheapest way to get the connector body.
Thanks for the insight, fellas. I ended up going the cut and solder route on this one.
