Hi guys.
My name is Pete, and I'm based all the way down in New Zealand.
I have recently become the proud owner of a 1990 80 series with 111,000ks on the clock. Its running the 1hdt and auto trans.
I intend to modify the 80 Series to be a capable offroad machine, but will most likely only use it for touring.
I previously owned a 1989 Nissan Patrol which i have just sold.
I have this for the seriouse stuff
So far i have gone through and done a full service (all trans oils, filters engine oil etc etc) and fitted a boost gauge, mechanical oil pressure gauge and trans temp gauge. I have rebuilt the front hubs due to a leaking axle seal and a few other minor things you expect on a 17 year old rig.
Have also converted the interior to sleep two adults plus alow storage and the ability to leave the rear seats in place.
I seem to be building a collection of parts in the shed. So far i have two new CV's as the others are noisey, but only when in 4wd (center diff locked), trans coiler, trans filter kit, 100mm coil spacers, adjustable panhard rods, front radius arm drop box's/links, frive shaft spacers and swaybar drop links. Just got to get round to fitting all that. I'm short of longer travel shocks to cope with the 100mm lift at the moment, trying to source a set of the RS9000's at this stage. I'm going with the coil spacers as i want to keep the ride quality of the standard springs. Will see how it goes though, i'm quite prepared to have to put harder springs under it.
Also on order at the moment is an ARB winch bar, Runva 10,000lb winch, 15 X 10 steel rims with -44 offset, 35 X 12.5 R15 Goodyear Wrangler MTR's and RV Tubes plus an Airflow Snorkle.
Also trying to get a part time 4x4 kit imported from Australia to put in it.
I will get some updated photo's as things progress
At the moment i am trying to figure out the bump stop extentions. I think 50mm will be all i need. I searched but coudn't find any pic's of the actual spacers (heaps of discussion on the need for the spacers though!!) Has anyone got a picture of the spacers??
Cheers,
Pete.
Cheers,
Pete.
I will get a reasonably close to 3.5" over standard height
