Quick help: trying to pinpoint clunking near rear diff
yes, thats the side cover/panel that you can remove. Drain the t-case before you remove it though, otherwise you will get a face full of gear oil on you.
Yes, you can drive with just the front drivedhaft in place and rear drive shaft off. BUT, I believe you got to have your front wheels locked (turn the locking hubs to "locked" on each tire)
Okay, This is where I always get confused. Also, go SLOW when driving at this point..... You should be able to just drive on 4-high and shouldn't cause issue. But, to play it safe, drive slow as if you were in 4x4 on pavement. Not sure what year your Fj40 is and your set up. Mine has the option to pull a Knob labeled "F.D." and it activities four-wheel-drive by pulling vaccum on a diaphragm. Yours might not have it.
Okay, so first try and drive forward or reverse with you just locking your hubs. If it works, cool. Remember go slow (not highway speeds here)
If not, you then need to pull the "F.D." knob. Should drive now. It'll send power to your front driveshafts and axle. If it works, cool.
If you don't have the "F.D". Knob, then does the truck just go? Ha, not familiar with the later style fj40s ; It should go regardless, but if not, switch it to 4 low and see if you can move.
I don't remember if at this point you're officially "4x4". You should be considered only front wheel drive (or 2wd) since your rear is off. But regardless, I wouldn't be cruisin' past 10mph just to play it safe. More on that topic later I guess.
Let us know what you find
Got it! Baby steps here to save the golden kingdom! Lol
with that cover off you will be able to see whats making that clunking noise when you were working dline by hand. If all looks good or you cant see anything unusual it may be in the nose cone, thats why I asked if you were sure the 4wd collar was fully disengaging. By the sound I bet you see it obviously once cover gone.
Thinking same thing. Stay tuned.
….back with the final update and holy cow it’s been a journey. I’ll be very careful here not to indict the previous land cruiser repair shop in Atlanta that did my transfer case rebuild, but clearly things were not set up correctly, including the preload with the new bearings. The shim they also used to too big, all affecting the wear on bearing rollers and cases.
Also found out they never use gaskets as part of the transfer case rebuild kit that I paid for and only used a red RTV sealant. I’m sure for most people that might work if they can compensate for the differences on tolerances, but clearly it affected the initial preload measurement, and when they put it all back together, had excessive wear on cases as shown below. Not event 2k miles on the prior rebuild and $1,500 out the window and lesson learned.
Im glad you figured it out. I hope you documented everything you found wrong. I would be going after that shop for some sort of settlement.
