QUICK HELP antenna '96
Chesapeake,VA
Ok i have the mast with the cogged plastic hooked to it. Now opened up my motor and i have a smooth plastic crimped to the spool. Calling the parts guy, crossing the vin number he shows only a mast and a motor setup no smooth plastic push dealio. My question,before i open up the part, will the cogged one work or do i need another set up?? If so does anyone have the correct part numbers. The antenna motor works i just need the plastic rod and mast not the whole deal. Thanks in advance. Trying not to bug CDan for i have solved most issues here so far!!!!!:hhmm:
I'm not sure what you mean by smooth pastic crimped to the spool, but I just did my antenna successfully on Friday night following the FAQ so maybe I can help.
The spool inside the motor assembly should basically fall out when you take the black round housing off. Inside the spool, the broken piece of cogged plastic cable should be present. Remove all of this broken cable and reassemble the entire motor unit. Once you have that all assembled and reinstalled in the truck, you will turn the truck on (no need to start it), and make sure the antenna is in the full up position. Turn on the radio, but leave the volume down, then press and hold the up antenna button until you hear the relay click off. This is all in the FAQ so, I won't keep repeating the instructions.
EDIT: I stand corrected, I thought all the power masts for these cruisers used cogged cables! Sorry for the confusion.
The earlier power antennas used the smooth plastic material. From my research when I did my R&R, I'm not sure when the switch to the cogged plastic took place but I thought it was earlier than 96. You may want to do more research to by sure if it looks like the cogged plastic won't work. However, it's possible someone "fixed" things before with the wrong mast material and you're finding it inside because of that.
Just to add to this... I have a '94 but the parts guy did not have a mast for my year and gave me one for a later mode (don't know what year, but it was very close)...
My Original mast does NOT have a cogged plastic line, it has a smooth plastic line that get crimped onto the motor. So I'm very curious about this also. I have not tried to used the cogged mast/Line but I was thinking that I could Crimp the cogged line to the motor in the same way my original smooth line was... they seem to be about the same diameter.
So yes... there are 2 different types of mast lines out there a cogged one and a Smooth one the gets crimped at the end to the motor...
Following the instructions here on how to change the mast should NOT work for us... since we HAVE to crimp the mast line to the motor with a pair of pliers... maybe I will take pics when I try mine and post up an alternate Mast assembly Thread for those of us with Smooth Mast lines:grinpimp:
cool thanks green truck thats my next step. I'm assuming that it was repaired w/bs. Gonna go look closely at the parts in thread. As for the rest of you illiterates read before you post!!!!!! jee humility is a highly regarded trait.
Hey sira dude the cogged one doesn't fit in the crimp!!! Thats why im here working my brain to do it riight!!! I ll keep this updated
Shot.... There goes my hopes.... It's been a while since I broke in there to look at the line width....
I know for a fact that my '94 came with a smooth line mast from factory...
When you say it dont fit.... could it be MADE to fit..:D
hey sira does your part have a metal spool????? The faq says a plastic spool bu i hav a metal one so maybe there is a older part in there. i gotta pull it out to see the numbers will do later gotta hit the P.O. before five ANd no i couldn't mod mine to fit to thick.
Bump??? is the inards of any of the models have a metal spool w/ the plastic crimped in??? That is what i need
Sorry...
I cant really remember, last time I tried to fix it was a while ago... I know the it was crimped with a metal crimp but I cant remember if the spool was metal also... I'm leaning towards saying yes... but my memory has suffered a lot from too much wiskey... :)
When i did mine the dealer ordered a mast that screwed in whick was wrong and he ordered the one that had a white notched plastic cable the one i needed they where the only two for 1996-1997
Still no answer? aaaaa Will the cog work on the metal or do i need another part
I just changed mine a couple of weeks ago. I have a '96 LX 450. When I went to get the part, after reading the repair instructions here online, they tried to give me the old mast setup (non-cogged) when I told them I have a '96 Landcruiser. I knew it wasn't right as it wasn't cogged and I had seen the correct part for my vehicle in the write-up. The Toyota parts guy double and triple checked the computer to make sure he was giving me the right part. The only thing we could figure out is that they were still using the old setup in the '96 Landcruiser (non-cogged) and the new setup in the '96 LX (cogged). He said they switched to the cogged setup in all 80s in 1997. You may want to double check with C-Dan or call your local Toyota parts shop but I think you want the old setup, not the new one if you have an LC (especially if the part you are seeing in your vehicle is the old setup).
Here's the quote from the writeup: Note: This applies to LX450s and late '96 and on Land Cruisers only. Maybe yours was an earlier model in '96 and you have the old setup. Hope this helps.
The 97 LC got the manually controllable switch that allowed setting the height of the mast height in memory. This had been a feature in the LX for two model years (IIRC) before the LC got it.
This may have been what I was remembering, although I am not certain that the cogged mast was tied together with the mast memory feature. Sort of makes sense though. The build date of my 97 LC is Oct 96 and it is set up this way.
It's important to always insist on giving the build month and year to the parts people, even if they don't ask. Good parts folks like CDan will ask, but doing this yourself is a good way to remind someone having a brain fart to double check that when looking up your P/N.
Yea i did all that guess i gotta break down and call Cdan Thanks guys My parts man has worked wonders till this point prob just dont have the correct numbers in his system
He's not mean, you make it sounds like a big task to call Cdan!
I wasn't even aware of the mast differences because Cdan must have automatically known what I needed when I started off by telling him that I have a 97 LX. This is one huge reason I like going through him for my parts. He knows just about everything about the model year and trim differences so I can trust that I am going to get the right parts the first time.
Before he retires, I hope cruiserdan grooms someone in that parts department to carry on the legacy!
EDIT: But I haven't heard one word about this, so I don't want to perpetuate some false rumor that he's leaving. That could start a riot.
I think Beno is the heir apparent--at least from what I've read around here.
