Quick Driveline Noise Question
I just want a quick clearification on this grrr noise that has been discussed to death. I had the typical 2.5" lift with a low, slightly noticeable noise when I'd let off the gas at highway speeds, such as on an exit ramp. I now have a 6" lift and get what sounds like a metal meat grinder when I let off at highway speeds, well mabye not that bad but way worse than the previous lift. So which one of these sounds would qualify as the grrrr?? I'm about to do front and rear double cardan shafts but just crurious which of my noises is closest to the grrr.
The 'slightly noticeable noise' would be the grr IMO. In my experience, sounds like that on decelleration often indicate bad u-joints. If so, they could be making a lot more noise at the increased angles of the 6" lift. Might want to pull the noisy shaft until you have the DC shaft.
-Spike
Bone stock I had a very similar noise. Replaced the u-joints front and rear and still did it. Removed the front shaft and the noise went away(kind of still has me worried about my front diff). Both shafts were also "rephased" and balanced. I have since installed my 850j's and med rears and have not reinstalled my front driveshaft yet due to waiting to install my gears and all new bearings and seal kit. Getting kind of frustrated with my tech at work that promised he could do it all 4 months ago!! Anyway interested to know if the cardan shafts fix your noise. :cheers:
coming off acceleration noise is the typical Grr sound when you have a bad shaft or should have a DC shaft install. The joints are unloading which allows the shaft to shudder.
When I was working through NorCalSam's vibrations he had some on acceleration as well and that was a bad slip yoke in the rear shaft.
For a front DC shaft I would go with a modified Tacoma rear as long as you can find a competent drive line shop to re-tube it. I recently had two done and have ran both now in my 80 and they run beautifully. My shop spins the shafts up to 3300 rpm when balancing unlike the more common 600 rpm.
Not to hijack, I was about to create a similar thread for my noise. At work on Wedneday night I pulled out my rear driveshaft (I love lifts and air tools!). I wanted to get it rephased, instead of the 45* phasing it was at before :rolleyes:, as well as replacing the u-joints and balancing it. On the way home (after scaring the crap out of myself wondering why my truck didn't back out of the shop and finally realizing the CDL button was the key :doh:) I noticed a crunching noise coming from the front end when I was A: on the gas, and B: turning. It doesn't happen when I coast or decelerate around corners, and it's only at a certain angle and speed that this occurs. While the truck was up on the lift I used Landtank's (?) trick of moving slowly from one end of the front shaft to the other checking for play, and I think my slip yoke is going on me. Would this be a fair guess? With both shafts in before, I also had the "grr" when letting off the gas at highway speeds as described in the first post.
I repacked my birfs a few months ago (<3000 miles ago). I ordered new spider kits from work, and I'm going to swap my newly refurbished rear shaft back in and remove the front and check it out. I got my rear shaft back today, and the shop said the slip yoke was done for, so they fixed it/replaced it (as well as replacing the u-joints with the Toyota ones I brought, painted and balanced, all for $20 :eek:)
[Disregard this info]On a related note for those of you looking for a DC Toyota driveshaft, I've been keeping an eye on the 4Runners that come in at work, and have noticed at least two 3rd generation trucks with a DC rear shaft. One was a 98, the other was 99 (the year the bumper got it's lower lip). Both were 4x4, one was the 3.4 V6 and the other was the 4 cylinder engine. So you can look for 4Runners as well as Tacomas for a Toyota DC shaft.[/Disregard]
:cheers:
:cheers:
NO. ONLY the TACOMA rear double cardan shaft matches the LC's front bolt pattern. The 4Runner's rear double cardan shaft bolt pattern is LARGER and will match the LC's rear t-case flange, but the other end of the 4Runner shaft WILL NOT match the LC's rear diff flange. The slip yokes are also larger on the LC's rear shaft so the only way to have the 4runner shaft work is to re-tube it with the slip yoke from the LC shaft. These 4runner rear shafts can be found on all '96-'02 4x4 4runners, 4 or 6 cylinder. I'm in the process of working through all this and going to check about the Tundra rear shafts as they MIGHT match the LC's front. Also the double cardan front shaft off an '83-'95 truck/4runner will NOT work either because it has a larger bolt pattern than the LC's front but smaller than the LC's rear. To confuse you more, an '80-'83 FJ60 front double cardan shaft will not work on the rear of an FJ80 either because of the change Toyota made in '84 to flange styles. I don't know of any more Toyota shafts with double cardan joints.
Once I try all this I'll write it up. Tomorrow I'm going to check on that Tundra shaft and maybe next week have what will work re-tubed for my LC.
I measured the bolt pattern on my dad's '05 Tundra and it appears the same as the LC's front as far as I can tell without droping it down. I would not take this for fact until I try to bolt one on. My favorite junk yard has two Tundras and maybe tomorrow I'll ride down there and try to bolt it on.
