QUICk Distributor Check!
Maricopa, AZ
Good or Not?
Don't know anything about this distributor except that it's got a vacuum advance. Looking for knowlegde about this item. The difference from USA to NoN-USA is a big advantage.
This would be for a 1971 TLC original set-up. Any complication or just general information would be helpful.
Thank you in advance...........
this is my first time on this forum. SO hello to everyone out there.
:beer: bottoms up!!!
Points suck. Get an electronic ignition.
Your cam gear looks worn in that pic.
I'm looking for info about this distributor because it's for sale. I take it from your opinion that it's not worth buying. I agree electronic is the way to go, that's why I have a pertronix 2 ignition. I've got a advance retard on my original set up. My plans are to find a vacuum advanced dist. then install my pertronix to gain performance and fuel economy.
I have rebuilt quite a few distributors, and sold quite a few more [including NON USA models], and I have NEVER seen that diaphram and advancer combo!
I'd be more than a little curious as to how they grafted what is basically a 77-78 diaphram onto a pre-69 advancer without generating enough heat to DESTROY the rubber in the diaphram.
I would definitely want to hook a vacuum guage to the outboard port on the diaphram to see if the diaphram moves the advancer. Otherwise, ALL is moot.
Best
Mark A.
thanks mark!;)
I was just down at your shop last month. I got the inspection done on a tuesday, I would have to say two weeks ago. I thought this was one of the one's that you should me. You had a bunch there from your recent trip. well I guess i'll have to save some money after the transfer rebuilt for the dist. that you carry on hand.
I linked up with tim two days after the inspection. Remember the whole pass it forward.
thanks for the oppuntunity.
thanks again for the heads up on the distributor. I whouldn't want to complicate things more.
I check the timing and compression like you said about a week ago. compression was 150 for 1,3,6 cylinder but 2,5 was 130 as 4 came out to140.
timing was way advance if i did so correctly.
a whole 14 degree's so i'm 7degrees advanced.
I'm waiting for the haynes manuel to come in before i do anything else.
thanks again!!!
