Quick Carb Question: Float Level
Just north of here
I rebuilt my carburetor over the Christmas break. IT wasn't too bad. I'm going to post a write up...and see if anything was done wrong ;p
I am just posting this up to make sure it is correct.
When adjusting the float level when the float is haning on its own weight, you just measure from the end of the float right? THe FSM makes it look like you take a measurement of the lowest point at the end between the float tip and the air horn.
SO what I did was measure at the end, while it was supported with its own weight.
Here's what I measured:
THANKS!!!
Measuring float height is kinda like measuring point gap IMO. It's a decent start point, but not the holy grail. Sometimes variations in needle and seat assembly height will vary, and the float itself could be out of spec.
Bottom line: what does the fuel level look like in the sight glass? You're aiming for the dot in the middle of the sight glass.
Readjust as necessary.;)
Hth
Mark A.
Best way I know of getting the level "on the dot" is to blow through the fuel inlet while slowly raising the float by hand. The cutoff point where you can not blow through the needle should have the top of the float parallel to the bottom face of the top portion of the carb (the section the the needel is installed in).
Mark...
