Quick ARB / Warn question
Misery's feed trough
I'm going to install an ARB front bumper. Eventually I want to add a winch. Can a Warn be installed without pulling the ARB?
I looked thru a couple of dozen threads but didn't find answer.
Winch ready ARB I presume...Yes is your answer. You'll really need two of you. One strong one to bench press the winch into place while the other bolts it in.
you bet sure thing.
I put a 12k in mine without removing.
it helps to have a floor jack handy and 2 people for line up etc..........
I did the M12 by myself with a floor jack and a couple of ratchet straps. Used protection... :D
it won't be easy but yeah you can do it.
Like others have said, it's a PITA. I used 2 ratchet srtaps to the top bar. That worked remarkably well and was controlled. However, I still needed a second person to start the first bolt as I pressed it into final position.
Either way, it really is a 2 person job. The bumper is not hard to remove, until you start filling it with lights, antennae, and other doo-dads.
you wont need any help, just take some viagra, its like working with 3 arms:D
