Quick and Easy Disc Conversion Question
San Antonio TX
What kind of grease do you guys suggest using for this conversion? Approximately how much does it take?
There are Aisin hubs on the mini axle and Warn hubs on the 40 axle. Which ones are the better of the two? and I believe they are interchangeable?
Lastly, Did you guys rebuild the calipers before installing them or, hope like hell they worked when first installed?
Thanks for all of the help on this conversion and I will be working on the "Mini Disc Conversion For Dummies" like me!!
Grease-
Wheel bearing grease for the wheel bearings and lock out.
Fing birfields- Moly(molybdenum disulfide grease)
As per The Book....
On the lockouts...
The Aisin's are better....but will only work on the 1979 and later fing birfs....so that means if you have 08/75-12/78 fing birfs, they will not work with the short bodied Aisin lock out.....
I only install reman loaded calipers when I go through and axle....seem like it is wasting time to not do so...
Good luck!
-Steve
Thanks Poser. So I get to use the Aisins? Sorry, long day at work, gettin' ready for a road trip for Turkey Day and I'm a bit slow.. I am using an 84 axle and putting the parts on my 73....
Grease-
As per The Book....
-Steve
Steve, so what type of grease are you supposed to pack the knuckle with? I did not know you were supposed to use 2 types of grease, I just bought the multi purpose stuff / wheel bearing grease. Does the Moly ONLY get packed into the inside of the birf?
thanks,
Noah
i used moly slip grease on everything (about 2 tubes), the aisin's are supposed to be stronger and re-building your calipers sounds good but if you pull them apart and find that you are going to need pistions for your calipers just go and get re maned ones from the store or i have been told that you can use 4 runner ones with a bit of grind/cutting on the backing plate....probably easier to find as well. hope this helps
