First off I can't tell you all how elated I am to have found this message board! For starters on a whim I purchased two FJ40's at once a few weeks back, one 74 with a bent frame, and one 72 with cancer, however both a complete in the parts department. (Sorry this is gonna be a long post.)
First I have dismantled the 74 and boxed all of it up, with exception of the larger parts like the tranny and axel housing. Imagine my surprise when I found that the 72 had a Chevy 292 in it! Anyway the 292 will not work for what I want to do, it needs a car, manifold and header to be any good, and even then I don't want it. So I pulled it and then pulled the tub off of the 72 to start sand blasting the frame. That’s now done and the frame is coated with POR15 and all shiny and new again. Here is where I hope you guys can help me out:
1. I have a 87 Chevy 350 TBI that I am going to drop in place of the 292, will I need to cut the advanced adapters mounts out and weld them in a new location? So far it does not appear that they will need to be moved, but I understand that placement of the V8 is crucial for cooling.
2. Drum brakes? YIKES! What’s the best way to convert the FJ40 to front disc? I looked around for a later from axel, and everyone I asked laughed at me!
3. Looked around and I can't find a good supplier for the OEM paint, I have a delightful forest green color (in places,) and I found the paint codes, but I want OEM, know where to get it?
4. Undercoating - What should I use? I have already cut a good portion of the tub out and replaced it with new sheet metal, I know how to prime the new sheet I installed, however how I keep the rest of the rig from rusting away?
Sorry for posting such a large message, and I could probably go one for a while longer, but I need help! Also I have tons of parts available, I may post a lengthy inventory if I have time in the classified section.
