Questions from the Mechanically Challenged
Missouri
I have a couple of questions about my '93 FZJ 80. I bought this rig last summer w/160k miles. PO rebuilds LC's on the side and I know him, so I'm comfortable with the truck. Don't know the last time it's had a tune up, etc...
First question deals with fuel mileage. I had AT 265/75 tires on the truck and was getting approximately 13 mpg in the city. Recently changed to 255/85 Cooper ST's and am now getting about 11. Should changing to those tires had that big of an effect?
Secondly, I recently noticed that when my truck is ideling (seems to be more at morning startup) that once it warms up and the RPM's come down, every now and again the truck will idle up for a while then idle back down. Whats up with that, didn't used to do that?
Thanks for the help, from the mechanically challenged.
Geoff
with the larger tire you are actually traveling farther than the odometer reads so you have to figure out the difference - ~4.5% off the top of my head for your change of just under 32 to just over 33. so take your mileage and multiply it by 1.045(or whatever the difference is) and then divide that number by the number of gallons. you should be able to find the actual diameters of the tires on the manufacturers websites.
Is the AC on? The idle will kick up when the compressor is engaged.
How do I calculate the offset for the increased tire size?
IIRC google Miata tire calculator or something like that. It's a little site where you can plug in your old and new tire sizes and get a % difference on what you're asking about.
That's exactly what it sounds like, the AC is one. However, with temps in the teens and 3 inches of ice on the ground I don't remember having a need for the AC!
I'll check the calculater site. Thanks.
gp
Over lunch I looked at my dash and noticed that I couldn't see if the AC was on due because the steering wheel was in the way, looks like it was. DUH!
Nice!!! All that fuss for nothing (how is your head gasket...).
Riley
Aw... That's a low blow! :eek:
Hey, Cascade Cruisers are doing there annual Bend or Bust run... interested in wheeling with us?
I would love to but I have to wait until I do not need the LC for a daily driver. We are in the process of buying a house so it will be a while... Crappy excuse, but someday the LC will be just for fun.
Also, I was not trying to be mean to the OP, just poking at him a little. I absolutely love it when I think that I have a huge problem and it turns out that I just did not check the obvious! This site has led me to that conclusion more times than I can remember.
Riley
I have been DD'ing the 40 this week so I can't remember, but doesn't the AC come on for defrosting?
YES - I don't think it comes on when you are in the 50/50 foot/defrost mode but it DOES come on when you click to full defrost mode (on my '97s anyway) - the AC helps to dry out the air. It will default this way when you hit the defrost button each time even if you press the AC button to turn it off.
To the OP, compare the idle behaviour with defrost and AC on and then turn the AC off and see if you notice a difference :D
*snip*Also, I was not trying to be mean to the OP, just poking at him a little. I absolutely love it when I think that I have a huge problem and it turns out that I just did not check the obvious! This site has led my to that conclusion more times than I can remember.
*snip*
I know you were... I was poking back! :flipoff2: (wait, that doesn't sound right... :bang:)
I'm pretty sure it only does that in the models with the "automatic climate control" (aka "biggest hunk of s*** in the world"), like the LX450, 40th Anniversary, and Collector's Edition.
My '94 didn't do that.
