Question on front shock replacement
Dallas TX
Ok, the stock current on my 96 LX 80 needs replacing..bad. Bouncy and squeaks.
I just pick up a set of Monroe for the front. However, the nut and tread is at 14 mm. The current stock is 17mm.
Also the metal pointy thing, thread is much smaller than the stock, it use a 14mm nut.
Will it be ok to put in or just return it.
also the rubber gasket and washer also smaller than the stock.
Return it and call Cdan for OEM. If one is bad the others can't be far behind. I would never replace only one shock. At the very least do the two front and you really might want to do all four. The price will be right with Cdan.
I think that he did pick up a set, so he is planning to do both fronts it sounds like. I did the same thing about 5 months ago. I also noticed that the shock threaded bolts and the hardware were no where near as heavy duty as the OEM. I still used them as I had already begun the project and didn't want to reorder and wait. The Monroes are OK shocks, but if I were to do it again, I would call CDan and order OEM. Seems like a much better product, and much heavier duty. Or I would go with a better quality after market off road manufacturer.
Call CDan for a complete set.
OEM shocks for the Cruiser are one of the better deals you can get. I was amazed at how inexpensive they were and what a difference they made. Also, Dan ships quickly.
Help feed his used dogs, you won't regret it. :)
I did return them. The thread and the metal sleeve is 14mm when the stock is quite large. I thought it might " snap" off at some point going over a pot hole.
did you have any problem installed it? even if the thread were smaller, I hate waiting for re-order too.:grinpimp:
I haven't really had any issues with them, and I am sure that they will do fine, but still wish I would have reordered for the better OEM or aftermarket.
