Question? how easy on changing front struts
Dallas TX
I look at the Haynes manual for possible do it myself front struts. Mine has been squeaking like crazy for the past 50K:grinpimp:. The weather will be nice this weekend and I might give it a run at it.
what brand? does it require two person? thanks
I assume you are referring to the shocks since LX450 does not have struts. It's really a breeze to do with regular hand tools. The only snafu might be the driver's side upper nut turning with the shock piston/shaft. You can either use an air impact to break it loose or vise grip the shaft to hold it in place
What kind of shocks are you putting in?
It is a 1-person job. You will need some tall jack stands. A minimum jack stand would be the 6-ton variants like these from Harbor Freight. The 12-ton stands are better for this job due to the increased height. The 6-ton stands go up to 24", the 12-ton stands go up to 30"
If it were me, I would leave 3 wheels on the ground, jack up the left front, and put the 12-ton jack stand under the frame, just aft of the left front control arm. Remove the left front tyre, then remove the lower shock nut ( stock is 14mm), then the upper shock nut (14mm). Put your floor jack (or bottle jack) under the left side of the axle and slowly lower it. Watch your brake lines and the diff breather hose to make sure there is enough slack that you don't break the line or pull off the diff breather. As the axle drops you should be able to remove the shock. You might need to unbolt the sway bar to get more axle droop. Install the new shock and repeat on the other side.
The rear is a bit more involved if you are planning to do those shocks at the same time (recommended.) Pics here in the FAQ and in the suspension installation section on the Slee offroad web site.
-B-
I might be getting old and crusty, but I left all 4 on the ground, used a nut splitter, and just replaced the fronts. The rears need to have the lower mounts removed first, then the top mount has 2 bolts that secure it to the frame and they fall out. Use a nut splitter on the top shock mount and reinstall.
Simple one person job with simple hand tools.
When I did mine about 5 months ago, I used a very large pipe wrench to grip the shock while I broke the bolt loose. It seemed to work very well if you soak it in WD40 or PB Blaster. You could also use the nut splitter as mentioned above.
Yes, you don't need to remove the tyres for just the shocks. I was thinking of a spring replacement at the same time. It seems like I swap springs 3x for each shock swap.
-B-
thanks for the clarification bro. I have no idea what to put in. I just know that it squeak like its on last breath!
I read the manual sêems easy, but you are right about the vise grip.
