Question - front rotor replacement.
Fort Apache: Victoria
I'm just reading up (FSM) on front rotor replacement.
I haven't done the rotors yet, and it got too dark for me to closely study the parts today. So pardon me if I'm asking something obvious.
After you've removed the hub and rotor together, Can the rotor be removed from /replaced to the hub without removing the oil seal and inner bearing? The FSM doesn't really outline this, and it's hard to tell from the diagram.
Basically, I'm preparing to replace my rotors, and I want to know what non-reuseable parts I need to ensure I have on-hand before starting. As I'm a half-hour drive from any auto-parts place, and my 80 is my only vehicle, I can't do a mid-day parts run.
edit: my entire front axle was serviced about 5,000 miles ago when the Longfields went in, so I don't expect anything to be seized or beyond salvaging.
Cool. So all I need is the actual rotors, and (maybe) the flange gaskets?
Iron,
Like already said, yes it can be done (SA-10 covers this). The non-reusabel parts that you should need are: Outer bearing, lock washer, gasket, and snap ring (maybe the dust cap if it was damaged in removal). All these were removed to take the hub and rotor assembly off. I would however suggest replacing or atleast repacking the inner while you have everything apart.
I don't think I need to also tell you but remeber to have the grease on hand to pack the bearings, lube the hub and also it would be a good time to lube all fittings.
Glen
Iron,
Glen
Outer bearing, snap ring, and lock washer aren't listed as non-reusable. Why do you think they'll need to be replaced? I figure the bearings should be okay after only 5000 miles, no?
Properly maintained wheel bearings should last for hundreds of thousands of miles. if not the life of the truck. Always reassemble the bearings in the same place, so they run on the same race that they broke in on. As long as it isn't over expanded the snap-ring should never need replacing. If the bearings are run loose, the lock washer can become grooved and need to be replaced.
Iron,
Sorry, I thought the outers were bad...If they are not then you can just repack them as you would the inners. As for the snap ring and lock washer they are listed as non-reusable in the FSM so I listed them out. I have always replaced snap rings (just how I was shown when younger) but I had never heard of replacing a lock washer that didn't show signs of wear or fatigue.
Glen
