- Joined
- Jun 28, 2007
- Threads
- 3
- Messages
- 41
Just when I thought it was safe to go back in the 4-by!
As many of you know I had a code 25/26 a couple weeks back. In the end I found a cracked mini hose and replaced it. Truck runs great, and no CEL until....
Yesterday, CEL returned. Pulled codes. Expected a 25/26 again, but only code 26 now (rich). In the course of the last 25/26 venture I:
replaced 02 sensor
cleaned injectors
replaced dist cap/wires/rotar
replaced sparkys (NGKs)
tested AMF
tested/cleaned throttle body
adjusted TPS
tested cold start injector (s/b 2-4 ohms, I got 4.1)
I realize a code 26 points to poss problems with injector/circuit, fuel line pressure, CSi, O2, coolant temp sensor or a short somewhere between one of the many sensors and the ECM... here's my question.
I pulled the #1 plug and the #6... yes, they're new but if it were running rich wouldn't the plugs have at least a slightly oily sheen to the top threads and/or firing tip? Both plugs looked beautiful. Perfect, in fact. The firing tips just becoming a little (light) ashen, insulator tips clean and white, and the first few threads slightly darkened by heat, but not oily in the least.
If this were your truck with these circumstances, where would you start? Does it sound like a faulty code (like maybe a short causing a false trigger), or does it take awhile for plugs to show signs of rich running?
In the meantime I'll go check the coolant temp sensor. Thanks again for your guidance!
replaced 02 sensor
cleaned injectors
tested AMF
adjusted TPS
