All,
I've got my dual battery setup wired, and am happy with it, but after Googling around I see that there is a debate about where to ground the auxiliary battery.
I have wired the auxiliary ground post to the nearby body ground along the inside of the engine bay. The ground point has good continuity to the battery ground and seems to work fine.
That being said, I see that some recommend running the ground direct to the starting battery ground post, others recommend grounding to the engine block, others recommend grounding to both the body and the primary battery. There doesn't seem to be a predominant opinion, or strong argument one way or the other.
I will be using this for self jump starting through a Redarc SBI, so it will see starting loads occasionally. This makes me think I need a more direct ground to the block, starter or primary battery.
I have plenty of cable, lugs, shrink wrap and a crimper, so it is easy to change if one way makes more sense than another.
I'm happy to do whatever makes sense, but would value your opinions to help me make an informed choice.
Thanks!
Thanks!
