Question about percolator style coffee pots
I have an old beat up percolater that I have used for eons. It has the glass knob on top to see when the coffee is ready.
One thing your lexus french presses can't do is work on an open fire.
What I love most about my ol' percolater is that I'm picking coffee grinds out of my teeth all morning.
Here is a percolator question for y,all. I need the glass knob for the top of the pot. Any ideas. How about the perk basket filters. Grocery stores here don't know squat about them
Check with ACE hardware or if your lucky enough to have a Mom & Pop hardware store they might have one. The other place to look is thrift stores, I think the glass dohicky is fairly standard on most pots at least I can swap them between all three I own.
Never seen filters, those are for drip coffee makers. They also don't sell perc grind in the stores anymore. Your best bet is to go to a place that has a grind you own coffer set-up and set the grind as course as it will go.
I've had to use drip grind before and simply poked a hole in a regular drip filter then tucked it into the perc basket.
Hey Rubi, we just buy any old coffee filter and then just punch a hole in it to go over the tube thingy. Works great.
We use a French press or one of those stove top espresso makers if it's the whole family.
If it's just the snapper and I, I use this: a #2 folding filter (the smaller ones) with a whole-punch near the top, middle and a dowel run through it with notches on the end to fit my cup. Put in coffee, put in hot water, repeat as needed and enjoy! I've seen kits for sale for the same thing and they probably work the same for a higher price.
That's a great idea, I like my perc coffee when I car camp but your method would be the s***z for backpacking.
^ Thanks! That's basically how it started...backpacking among non-coffee drinkers and just kept for use while regular camping if I was the only one drinking the bean juice.
The trick is getting the hole located just right, in the center and not too low or high, and in a filter that will fit your cup. The small filters work for a large/wide mug. Same with the notches on the dowel, cut so the dowel won't move too much and you don't end up with said filter and grounds in your cup. I had to re-create the notched dowel from a random stick once (dowel was lost among our shjt), easily done. Also used a flattish skewer on another occasion.
And, it basically takes up no space, biodegradable, etc...
Just got back from New Years Eve camping in Sequoia Natl Park and my 30yr old percolator came through again with some excellent morning brew! Put the burner on high till it percolates, then turn the flame down and let it slowly bubble up. HOT coffee!
It's kind of a hassle to clean the perc when camping, so what I've been doing lately is just dropping one or two of those coffee filter packs in the "cowboy pot" and let it boil for a few... Not bad, particularly when you're cold as hell and stiff (back ;)) in da mornin'
Cleaning is easy peasy. Dump the left over coffee if there is any then add a cup of water to the pot and heat it up, meanwhile knock the grounds out of the basket into the fire pit, wipe the basket etc. with a dry paper towel. Slosh the now hot water around in the pot and dump it in the fire pit. Shake the grounds out of the towel and use it to wipe the inside of the pot out. Done.
I got tired just readin' that ;)
As stated above, it takes quite a few pots to get it right. I use a 9 cup, with 5 tablespoons of grounds, once boiling I then remove most of the the heat to a slow perk, 7-10 minutes depending on the strength of the grinds and how strong of coffee that you want. Funny to find this post, I am enjoying a cup of perk now. Currently I am brewing with Tim Hortons grind, @ 5tbls for 7 minutes give it a few minutes once removed from the heat and the grinds sink.
My methodology.
1 scoop of coffee per cup i.e (14) cups of coffee = 14 scoops
percolate 1 min per cup i.e (14) cups = 14 min.
Best cowboy coffee in my book but I like very strong flavorful coffee.
Powerful enough to turn goat piss into gasoline.
:beer:
Well said Master Chief.
Ok, call me old school.
I have a 24 cup coffee boiler. Looks a lot like a coffee pot. You see 'em in old western movies, sitting by the campfire. Odd thing about that, you always saw 'em by the campfire, but you never saw anyone packing one around. Maybe they just left one at every fire ring.
It's not a percolator or a french press or defibrilator or anything that high tech.
It's a big pot, narrows at the top. Has spout on one side a handle on the other and a bail that sometimes has a spring insulator in the middle of that. Has a lid with a little handle on it.
Works like this:
1) fill 2/3s full of fresh crick water.
2) put three big handfuls of coffee grounds in.
3) set on a rock next to the campfire with 1/3 to 1/2 of the bottom of the pot exposed to the flames. Will also work on a camp stove.
4) when it boils take it off the fire and pour 1 cup cold water down the spout and through the lid, let it set for a minute.
5) pour coffee.
Notes:
1) don't dump the grounds when you get low, just add another handful and more water.
2) some folks add eggshells to the mix I never did and couldn't tell a difference when I had coffee made with 'em.
3) you can add non-nutritive sweetener to the coffee if you like, I prefer the Jack Daniels Old Number 7 brand.
3) don't wash the inside, just rinse it out, the residue adds character.
4) don't wash the outside, carbon build up helps heat transfer.
5) get a canvas bag to pack it in to keep all the carbon off everything else.
6) whenever there's a visitor to camp, offer 'em a cup of coffee and some of that sonofabitch stew in the stewpot.
