FJ40/60 axle if you want the stronger third member, and not have to dick around with cryo gears.
ditto ! and you have the 30 splines for those 60 wider axles ..
Front axle sees a lot less stress than the rear.
A hybrid Ferd9"/with 60 outers would be your best bet..
35 (or 40 spline inners) with a decent set of knuckles..
Scott at rockstomper had a set of AL 60 knuckles on the rear of his buggy. Worked awesome..
The knuckles will rip off..
My god you could spend a ton of coin on a toyota rear steer axle that is weaker in the end than a D60 with $300 worth of shafts..
Should be entertaining, as long as he is not broke in the middle of the trail.
6 bolt knuckles are not cast with better materials ??? or thicker as well ? what was the point of building them ? stud count, stud materials, etc... DO nothing when the top of the knuckle pops off. i have paid no attention to 6 bolt talk.
d60 stuff is stronger just cause its bigger in every aspect.
however STILL very little leverage based on CL of kingpin to knuckle studs, marginally wider then the same toyota measurement. HOWEVER knuckles
are stronger in that area.
From the Trail Mart Web Site "The knuckle housing is also thicker then stock and larger gussets have been added around the outside of the knuckle for extra strength."
looks like they are a bit thicker than stock.. Obviously time will tell, based on how they are designed it looks like people wont be able to break the knuckle like they are on the stock ones..
Fuel for the fire... 4-wheels steer Toyota buggy, STOCK birfs till the 30 spliners come in, he drove it like this all day. Didn't break 'em.
http://media.putfile.com/100-5714
