quarter panels and sil
Ruston, Louisiana
I was considering cutting out and replacing my rear quarters on my 79' 40 due to the questionable filler job by the p.o. on th corners. Then as I was getting off the interstate the other day I got clipped on the right rear corner. Of course this wiped out one new tail light and my emblembs. This also revealed some really poor bondo over pop riveted tin body work. Ive been researching for a while and have decided to replace both quarters and the rear sill. I like the ones from heritage because they replace all of the damaged metal and are supposed to be more rust resistant. I was wondering if anyone has been able to buy from them direct or do they only sell through dealers? If so who do you recomend. By the way, to add insult to my injury the driver that hit me was one of my employees driving one of my trucks.
Few things: Heritage is owned/operated by TLC4X4. I have one of their economy panels and the quality is good. Their premium line is made of thicker steel.
I believe that Heritage/TLC4X4 sold the line (at least the economy line) over to IronPig. A lot of the stuff is still in transit between CA and VA. IronPig has been good with returning my calls - so I would recommend leaving a message. Also, if you're redoing your sill, you may want to look into CCOT's as they are truest to OEM that I have found. I've included some pics in my buildup thread - see sig. Good luck with the repairs.
I was at Iron Pig this weekend and can confirm that there are some Heritage/TLC panels and half tubs in stock. The rear quarters I saw have the wheel wells attached - I'm not sure they have just skins yet if that is what you are looking for. Did see some rear sills too. Give Lance or Cam a call @ 540-361-7400 or 1 866 IRON PIG - they will help you out.
This is CAM with IPOR
Yes we have just recieved a small shipment in of the economy line panels
We love most of it and some is very good but can be worked on.
Call us up at the above number and We will let you know what we have and, or how long it will take to get another order in for our stocking purposes.
THANKS AGAIN
CAM
If you need quarters, you need inner fenders...
