Quarantine Restoration Help
Honolulu, HI
Aloha from Hawaii guys! Since we are on a stay at home order, I've been getting to some things that I've been putting off. I've got some isolated rust spots that I'm trying to see if it makes sense to restore or leave as is. I'm mostly concerned about the one random rusty bolt on the drivers side engine bay, and hood latch and catcher. None of my cars, nor my other 2 100 series have had this problem before. Thanks in advance.
I'd just buy the latches and catches new from dealer. For the rest, take the bolts/tie down off, wire wheel them or sand them down to silver metal, prime and paint. I like VHT epoxy paint for all the misc stuff like this. It's only a little more expensive than generic spray paint and it's lasted over a decade on numerous parts over the years. Super easy and effective.
Gotcha. Will look into the paint. Seems simple enough I hope haha.
Any ideas on the rusted spots below?
View attachment 2263484View attachment 2263485
99.5% sure that's the parking brake cable and brackets. I'm not very familiar with the 100 series parking brake cable specifically, but in my other vehicle experience the failure point on those is the cable itself. The parts you see are not the actual cable (I don't think). The cable is inside the sheath and can rust and freeze, stretch or snap. If you can avoid that or prolong its demise with a simple disassembly and liberal WD-40 application, that might be worthwhile.
correct, thats part of the e-brake cable line assembly. there are 2 different cables, one front to rear of truck and another between the 2 wheels if I remember correctly.
Got it. Do you know if that circled part is easily replaceable? I'm looking at a parts diagram, but cant seem to find that specific part.
I would recommend using Partsouq to help you find the proper part number based on your VIN entry. From there, once you find the appropriate part start doing your searching via the part number as you may be able to get it close in price of Partsouq but within the US. Some of the larger online Toyota dealerships will match the Partsouq site prices at times, not always though.
