Pyrometer
I have a 1996 80 series project and was curious if anyone with a supercharger on the 1FZ engine has installed a pyrometer, and if so, where did you install the probe on the exhaust manifold, and where did you the instrument?
I have searched some out here, but most of the threads dealing with a pyrometer are in reference to a diesel, and there is only talk about them on the gas engine. Any help would be great.
:cheers:
Try searching EGT along with supercharger.
George Scolaro wrote up a bit on his too.
George's 80 Series Land Cruiser and Nissan MQ Patrol
Also, the particular brand of pyrometer you purchase will (should) have detailed installation instructions as to where you would want to place the probe.
You can put the gauge itself in an A-pillar pod, cluster on top of dash,or in the dash - I've seen at least those done so far.
:cheers:
The closer you have the probe to the engine the more accurate the temp reading is, although on a supercharged engine you dont have as much pressure/heat drop around a turbo.
I would have the exhaust manifold drilled and tapped myself, or if this is difficult then I would look at getting a bung (nut) to match the thread of the probe, which will probably be a NPT thread, welded to the exhaust immediately after the manifold.
There is a thread out there about using an aftermarket acura integra (i think) gauge pod on the A-pillar, which gives you the option of running other gauges as well, i.e. boost and and oil pressure.
:cheers:
