You should do an inspection of the valve. The location varies on the pushrod cover, but, it is there. I think that the manuals suggest cleaning them in solvent. A PCV valve is a flame-arrestor as well as emissions equipment, so must close when pressured from the intake side (backfire). It normally has vacuum on the intake side, so it needs to have proper OEM vac function. I don't know how to perform a bench test with any PCV valve to say yes, no, or maybe. I run it as long as it isn't pitted with rust, the spring isn't broken (had that on a brand new OEM one) and, that it is clean. Also, look for foamy oil.
