- Joined
- Jun 17, 2009
- Threads
- 2
- Messages
- 6
I have driven my old red 1992 FJ80 300,000 miles.
Recently I purchased another 1992 white FJ80.
The white one was having rough idle issues and barely passed emissions. It's engine had been rehoned after a oil drain plug fell out.
(1) I replaced plugs, wires, rotor, cap. This did not smooth out the idle issue.
(2) I did a compression check and 5 of the cylinders are at 120 psi and one is at 110. I had spark at all plugs. I did a wet compression test and that boosted the psi to 150 or higher in all cylinders.
(3) There was considerable smoke as the oil burned off, but the idle became worse. I cleaned the Throttle Body, and this did not improve things. I pulled the power to the battery to reset the computer. No change.
(4) I took the white cruiser on the freeway to try and speed up blowing out the oil from the compression check.. it was misfiring at high speed.
(5) I came back and parked it, went out to restart it and now no spark.
(6) I pulled the plugs after this, and plug (1) and (4) looked like their gap had been smashed to the electrode... very weird as they had been new plugs. I replaced them, made a note and once I get the crusier to start again, I will check them. The other 4 plugs looked brand new after this ordeal and are firing nicely. Not sure who did the engine rehone, but checking into this.
I have swapped the following parts between the white one that does not work and the red one to see if I can trace the part that is not working.. thus far the red one still works fine.
Igniter
Distributor Coil Wire
Distributor Ignition Wire Set
EFI fuse under hood
After swapping out the Distributor Ignition Wire, we got the white cruiser to start for about 10 seconds, very rough idle and then it quit, we were back to no spark when I pulled a plug and tested it... hmmm strange.. I put the prior wire set that I thought was bad, back into the red cruiser and it fired right up.
I have found a short in the connector that monitors the airflow valve in the intake air boot.
I have also
Checked all fuses- okay per visual check
Engine Check Light is not on
I swapped out the ECU and a little black box alongside it from the known good cruiser, which had had the check engine light on and has been running rough... After I swapped out the one from the white to the red, the red cruiser fired right up, the error code had been erased, and the old red one is running very smoothly. The white one still has no spark...
Is there a relay that could be bad, or wonder if there is a short somewhere .. I am getting puzzled as to next steps.
Any suggestions would be appreciated.
Mark
Igniter
EFI fuse under hood
I have also
Mark
