Puma Compressor Wiring Kit
LandCruiserPhil
Peter Pan Syndrome
Supporting Vendor
Graham County, Arizona
Puma wiring kit 100% complete -
►Pre cut #4 cables
►All terminal end in place, crimped, and shrink wrapped
►All needed hardware included
►Reset able Bussman 50A Breaker at battery with safety shut off
►Anderson connector for connecting large #4 cable to compressor #10 wire.
►Instructions on connection and wire routing
PUMA electrical wiring for Dummies <link
The design is for a drivers side battery and drivers side Puma compressor using our mount. We can customize any other type of set up also.
Basically everything you need to get your Puma running safely. No special tools needed. You will need to crimp the wires on the Puma to the Anderson connector but all that is needed is a hammer. This kit adds an additional overlooked safety ground the the system while using and grounding the frame.
$162.50 Shipped
Local pick up discount available
waytekwire? :p
Edit: Btw, these are very high-quality components. This is what we use in the auto industry. Top notch.
