Puma Compressor Mounted in the Rear Qtr Panel with Pics
do you have any more info on the speedflow braided lines?
Speedflow braided hi temp teflon hose & Speedflow fittings
All the info is already there. You will need to find your local supplier & drop in with your compressor & what ever you want it to connect to.
& they should be able to supply the correct fittings & hose size for your application.
Or if you can not find a Speedflow supplier try Aeroflow.
Hamo
How has this set up lasted for you? Any issues with heat or otherwise? I’m debating doing this.
