so no dyno results w/the 100.
80 tech has nothing on this thread!
Thanks Dean.
[ILater she asked if I wanted a tour and I took here up on the offer.
Dean
Ok, I looked up the company and decided to go and pay them a visit…..especially since they were directly across the street from my work!
I must say they have a very nice shop staffed with some of the nicest people. I was greeted at the door right away and asked if I needed help.
I said I had some technical questions & she offered to help me,- she was very knowledgeable and helped with my questions.
The shop is very large & clean. She showed me a demo setup. It had a coil hooked to a regular plug with a pulsstar on the other (facing each other). It was very impressive! You could see the difference.
We moved on through the shop and seen the dyno in the back room and everything else they did.
I asked about the spark being such that burning through the piston was a concern I had with hypoeutectic pistons. Some how using Plasma sounded like it would burn the piston to me. She wasn’t sure about the hypoeutectic pistons and asked if I wanted to talk to an engineer.
That’s when I meet Michael G. (Manager of Engineering). It was a joy to talk with him, and he explained how the system works and there was not danger of melting or burning.
After a short while we diced we would put my freshly built 383 stoker (71 GMC) on the dyno and run the numbers. My truck isn’t complete just yet but will be soon.
I got a set of plugs for the cruiser, and on the way out he introduced me to Nathan K. (product testing & technical service) he is the guy I’ll be setting up the dyno with.
He asked about the Land Cruiser and said he was a founding member and ex-president of High Desert Cruisers and knew C-Dan along with a few others.
He said they did a fuel economy test on a 100 series and came out with ~ 3% increase (1 MPG). Their dyno isn’t a AWDso no dyno results w/the 100.
I wanted to call back to ask Nathan a question about his test with the 100. Because if he just popped in the plugs and didn’t reset the ECU he wouldn’t get the best results, due to the timing being pulled from bad gas etc.
I’m figuring 3% @ 30000 miles year = $192 savings. So not quite paying for themselves with that analogy, but if it helps with torque and hp it’s a good to me. Like I mentioned if he didn’t do anything to reset the ECU, maybe that the 3% could improve?
I get them installed and report back. If anyone has any specific questions I’ll contact Michael and find out.
Dean
