I replaced my rear pinion seal yesterday and started having a pulsating almost grinding sound. It’s not a constant grind too, it pulses. Maybe I messed something up replacing the rear pinion seal. That job was super straight forward so I cant imagine messed something up. Would that happen if i tightened the center 30mm pinion bolt too tight? I have terrible hearing so i cant figure out if its coming from the front or the back of the car. I sounds like a have a bearing out. It much more prevalent at 20-40 mph and cant hear it at all low speed and higher speed. Maybe drive shaft related? Please help!
