So my rig had been on jackstands for nearly 4 months as I took my sweet time completing a few jobs including a new rear Harrop locker. While it was out of commission, I replaced all remaining soft brake lines I didn't replace last year, and put in new rear calipers, discs, etc. Note: I did the front brakes with Toyota reman calipers etc. about 9 months ago and experienced no braking issues before putting the truck on jackstands.
The problem I'm having now:
- Brakes seem slightly spongy; I think another bleed is in order.
- For the first 2 or 3 stops, the truck will noticeably pull to the right, and the pull can physically be felt in the steering wheel.
- After the first several stops, no problems - the pull goes away.
- No pulling when not on the brakes at any time.
Despite having just done the rear brakes, my gut is telling me that this has something to do with the fronts since I can feel it in the steering wheel.
Questions:
1) Is it possible for brakes that have sat for a long time (~ 4 months) to kind of begin sticking?
2) Can air in the system cause symptoms like I'm describing? Since the system is hydraulic, I would think no but I'm definitely no expert.
3) What else do you guys think I should be looking at as the source of the problem?
Thanks!
Questions:
Thanks!
