Searched the forum for brakes that pull on a panic to no avail - thus I am humbly asking you 80 gurus for advise and direction.
I have a 97 LC with 185,000 miles front, center and rear OEM locking diffs and mildly built with a 2" OEM lift, ARB front bumper with a 12K warn for camping and used as a DD. As far as I know it has not been in any kind of wreck and is very clean and solid.
Here is how it started - had to make a panic stop one time and had to side step to the shoulder to avoid the car ahead of me.
Brakes did not pull to any side but then again they did not stop the LC fast enough. I brought it in to a very reputable auto shop to install in the front and rear new calipers, rotors, brakepads and changed fluids - now stand on the pedal and it will actaully chirp the tires. BUT on panic stops it pulls dangerously to the left - on normal application of pedal pressure - no problem - only on panic stops !!!
Shop thought defective calipers - changed them out - no change; thought they had a kink in the inside brake lines - replaced - no change; checked tire pressure and alignment - no change; replaced calipers and pads to a different brand - no change; I need HELP !!!!!!! Don't know what to do and where to go from here.
Is there a proportioning valve that controls Left & Right rather that front and rear?
Thanks for taking the time to read and hopfully some advise,
Frank
Frank
