Pulleys still squealing
Ogden, Utah
So, after replacing both pulleys on my 92, and I am assuming close to proper tension, my belts still seem to squeal, or sound like a rusty wheel. I have tightened each pulley a couple of turns and loosened each and still have same sound.
I have sprayed some water on each belt and it goes away and then returns.
I have checked the little roller pulley for the A/C, it spins freely and does not feel tight.
Does anyone have some input as to what to do or what can be done to solve this problem?
I am also wondering if it is the A/C plate, can that be rebuilt? or the bearings replaced?
Thanks in advance, all input would be great.
WoodyFJ80
(John):cheers:
Are you using new OEM belts? I just replaced mine a few weeks ago and the difference was dramatic. the noise goes away when you spray water on any belt, or one specifically? could it be your air pump making the noise? when I was trying to isolate the grinding noise I was having(alternator) with a dowel, I noticed the air pump was making noise too. I bypassed it with the Gates TR22525 belt.
Visually check the alignment of the belts from the side, with the motor running. You may have a component slightly askew causing the noise.
I replaced the bearing on the a/c pulley on my 91' several years ago that did quiet things down a bit. In hindsight I shoulda replaced the whole pulley.
X2 on the OEM belts.
Thanks for the replys, I do have OEM belts, which are about a year old, things do look to aligned as well. I will try the lava soap trick.
The noise seems to be isolated to the passenger side area, more in and around the power steering and the A/C area.
Any other input would help greatly, it is loud and anoying to say the least.
Thanks WoodyFJ80:cheers:
P.S. the fan clutch is brand new.
Heres a long shot, check your power steering pump fluid. My pump was leaking, and when it got low it really squeeled. It was leaking because the ps pump was shot, and soon it squeeled whether or not the fluid was low. It sounded just like a loose belt. Once i rebuilt the ps pump, no noise. My truck is a 92 as well.
I have had the same problem since I got my cruiser. I just recently fixed it. For some reason the OE belt for the alternator only last about a month before squeaking begins. After it starts you can try just about anything but it won't go away for more than 15min or so. I even got a belt tension gauge to make sure all the belts were in specs. When I replaced my alternator I got a Goodyear belt for the alternator. Has been quiet for 2-3 months so far. The belt is a little softer rubber it seems which is all I can figure helps it. Also a problem I had in the past was the A/c Idler bearing thing. You can take it off and just replace the bearings for about $5-$10 or just leave it off. I ran with out it for a year.
:cheers:Once the pullies are worn a new belt wont make 100% contact onto the V shape of the pullies.The only way to stop the niose is to replace all the pullies and belts at the same time.
Thats one of the main reasons for the popularity of the serpentine (single flat belt) in later models.
I don't know about replacing them all. It seems the alternator pulley is softer than the others. Either that or I was just lucky.
Update:
So, finally got around to follow some advice I received here. I took Inkpots' advice to start with and what ya know.... IT WORKED!!!!!:cheers: to inkpot and his advice of using some lava soap on the belts and pulleys, except I used some orange hand cleaner with some pumice in it and it was a liquid, easier to rub on the belts and pulleys. I recently just took about a 300 mile round trip camping with my girls, dog and gear, no squealing, and I received 14 mph with the a/c on at times.
But, thanks again to everyone and just thought I would update, since alot people don't tend to do this.
:beer::cheers:, WoodyFJ80
