Pulled the trigger on a 40th this week...
now time for the CDL switch...is Slee the place to get it? Should I do the Pin 7 mod? Thanks.
Glad to see you found your truck. Slee or CDan can get you your CDL switch, and the 7-pin mod is a handy option to have.
thanks, I appreciate it. I assume $68 for the switch is reasonable? Who is CDan? Where is the link for the 7-Pin Mod?
Lantzalot,
Your sig line cracks me up.
Buck Buchanan
I'm not having any luck with the 7 pin mod search...what am I doing wrong? Other than breathing...
It might be in the FAQ
Thank you! I've been to the Slee website but I was trying to figure out what the 7 pin mod really does? Should I just get the CDL switch from Slee?
The search function is your friend. I should warn you, though, that once you discover how to use it you will spend countless hours reading old threads. There is a lot of information in this forum.
In short, the CDL switch will allow you to lock the center differential in high gear. The 7-pin mod will allow you to drive in low gear with the center differential open.
Congrats, but....
-Ferg-
gotcha. Thanks! Can't seem to find CDan though...
thank you!
