PTO Winch rebuild
You guys are doing a once-in-lifetime rebuild of a PTO winch and you're shopping for no-name seals when OEM brand are available?
If you are compelled to go generic, at least find a reputable supplier with name-brand seals.
@73FJ40 - thanks! These seals are for the aluminum gear case that is attached to the transfer case, not the winch itself. The Type T Oil Seal (#90311-28004) is a single lip and the ones I removed were a double lip. If this does not make a difference, then should I go with the Type T Oil Seal (#90311-28004)?
Here’s a great thread on the pto winch with most of not all of the needed part numbers
