PTO Shifter Bent - why?
Fair Play, SC
I am slowly restoring and installing a PTO winch. My shifter shaft has this S curve shape. I have seen pics of both straight and bent shifter shafts on Mud. Based on my trans hump height, I think I need a straight shaft, but don’t want to mess this up. Anyone know why some shafts have the S curve and if there is any issue with straightening it out?
Thanks in advance,
Don
I've straightened Landcruiser transmission floor shift levers and 4WD transfer-case floor shift lever in the past (where PO's got creative) and they never quite get back to original, always dings/ dents/ curves/ flaws/ hammer marks after straightening.
Bent shift lever are more common than the straight ones in my experience. This leads me to believe they may have come bent at some point since the S bend is so common. Toyota just never bothered to change the diagram to reflect the bend.:meh:
If I keep the bend there, which I am okay doing if it is OEM, it is going to be a bit tricky to figure out exactly where the transfer hump hole should be cut. I have seen some nice diagrams here on Mud, but I don’t know that they accomodate the bend. It was a PITA to get my hump removed to screw the lever rod in the top of the trans. Not sure how to best approach this.
All the ones I have the opening wouldn't change. The pivot point is on top of the transmission and just below the hump. As little as a winch would get used I just couldn't why someone would want to move lever further back instead of up front and out of the way. If not factory why would so many go to the effort of doing a S bend instead of just just a single bend. If on a V8 conversion with a stock transmission would make sense being seen enough transmission shift canes with the bend to avoid the heater. But not sure the PTO lever that are bend would have a sharp enough bend to clear the heater. The 40 series is a new come to the classic collector and finding pictures from original owners from the sixties and seventies who bought them new is hard to do. Only 40 series I've owned that had a factory PTO winch is straight. But it was also made in 1961 and under 1000 in the number of FJ40 made.
Living in the past,
Would you by chance have a pic you could post up of the ‘61 straight shifter coming up through the hump. I would like to see where the knob is located in relation to the heater.
Thanks for your help,
Don
Living in the past,
Don
A factory installed heater in the center of the transmission hump did not arrive until some time in 1964. Picture would not show how close to a heater it is.
Here’s a ‘65 just in case...
Living in the past,
Don
If you’d like I can post some pictures of mine. I also have an almost complete pto with linkage I no longer need
No lift, I have a front mat from SOR that’s puffed up off the hump so that’s hiding several inches of the shaft.
My trans hump is 5” high at the PTO shifter pivot point. Part or most of the bend in the the shifter would be at the hole. The diagram I have seen shows the hole starting 1/2” rear of the heater face verticle position, which is directly above the pivot. However, the lock out trap door I have is only 2 1/2” long. So, maybe the bend is there for the shorter shift range? To keep the bend I would need to move the hole further to the rear, behind the pivot point, I think.
Billsboat,
I would love to see pics of your PTO shifter. Thanks,
Don
So here is what I am going to try. Might need a little more work to get the bend exactly right, but here is the first go round.
Before:
After straightening. Probably need to adjust the linkage to bring the knob back away from the heater a little more
After looking at more pics on Mud, decided I need to straighten the shaft a bit more and have the bend curving back, turning the shaft around from the last pic. Here is where I am now, so I think I am ready to cut the hump.
Here is a diagram for the PTO cut out I got here from another thread some were.
JP
JP
Excellent! Thanks for the info. This is just what I needed to double check my measurements.
Do you have a date on that diagram? Looks a little too far back. My 61 I posted a picture of earlier is a different setup and has a bracket the shifter pivots off further back. Would be 100% sure your using the correct measurements before you cut.
No I don`t It was posted on mud but I don`t know were or by who. I copied it when I was installing my pto shift lever. I ended up just cutting a hole just above the pivot pin mounting point at the trans.
JP
Well, I went with the cut starting 1/2” from the face of the heater (as shown on the green hump in the pic above), which worked out fine. Probably could have cut it even closer to the front of the hump.
Here is the final product, so far.
