PS pump rebuild
Purcellville, VA
I bought this PS pump core off a mudder a while back and am now starting into the rebuild. Inside the unit, there is a boogered up spot. That notch in the picture has some wear marks to it. Do you think the pump is still ok?
Hard to tell from Pics, but my gut is saying No, that is not OK.
Pump is full of Power Steering Fluid, which is slippery stuff and will likely leak past this point.
Rebuild Kits only come with seals, not internals.
Rebuild and test if your worried or buy one already rebuilt, or use the part of of your current pump.
If I remember right, I incurred the same damage when I rebuilt my pump. I smoothed it out with a rat tail file and no leaks so far. That's just a bushing, I don't think it's a sealing surface. Fwiw
Difficult to see for sure in the pic, but looks like most of them that I have resealed. How does the shaft look, excessive play when inserted into the bushing?
thanks guys. no excessive play, but I get the new shaft bearing tomorrow and I'll reinstall. One other question. When I took the pump assembly out, the fins fell out. Is there a correct orientation to put them back in. I "think" one surface is slightly concave. Does it matter how they go back in? Any thoughts? Thanks again. Jeff
One edge of the vane is slightly rounded/convex, goes out towards the cylinder, the square edge goes in the vane pocket, rotor.
I spent IIRC, 300 on a pump from Autozone. com, took a couple hours, and it groaned for about a half hour after install/bleeding. It was the quick, cheaper alternative to the leaking, non functional one it had.
Thanks guys. Took about 3 days (1.5 hr per day) getting it apart and putting back together with a few days in between waiting for the shaft bearing from Amazon. Got it back together. I suspect I could do my next one in about an hour from start to finish. Thanks for the help.
