PS Pump Question & Noise Diag.
Hotel M-F, home weekends!
Ok everyone, I accomplished a lot today with a few questions:idea:
Oil pump O-ring-THANKS MUD.:cool:
New Idler pulleys.:D
New PS pump.:censor:
Rig 1996 FZJ 80
Few questions that maybe folks could ponder:
1--PS question--(during replacement I filled the pump with fluid to help start up)
-after pump replacement I raised the front end off the ground & started the rig.
-turned fully lock to lock.....bubbles came out but still had groan.....?
could I need to bleed it more-let it run approx 10 minutes but still could hear it.
2-----Knock----------(good oil pressure-same as before)
After replacement of all parts mentioned above I started the rig to bleed the PS system.
During this it seems to sound as if there is a knock.....did not notice this before.
Could I remove the PS pump & isolate if the noise could be coming from there or something else....?
My logic is that that was the only internal part I removed & replaced so maybe by removing it I disturbed something?
Thanks MUD!
Clutchee--To bleed the 80 series power steering, the motor has to be off. If it's running, it seems like the air never clears out of the system. So pu the front up on stands, cycle lock to lock about 20 times. Makes sure the fluid stays full. If it still groans, then you have another problem.
Knocking???? I hope not. Any problems with the PS pump install? And you have good oil pressure? Hopefully, nothing serious.
Ok so I bleed it wrong-gotcha!
So tomarrow bleed it & it "should" stop groaning.
You mention that if it doesn't I may have another issue.....any ideas?
hey, how much was it for the new ps pump? Mine leaks like a hose with a cut.
I'll have to check....but I was working on wifes 96 FZJ80 & notice yours is a fj80.
Might be giving you a apple price instead of a orange:hhmm:
The other issue is that some pumps just groan, like NorCalDoug's. Even Toyota recommends the addition of some fabric softener to the ATF power steering fluid (I kid you not-ask Cruiserdan). I would never do this, but some do with good results.
Since the pump was new, I'll bet you bleed and it stops, but Doug got his replaced and it was still groaning last time I saw his truck in action.
