Anyone know what size 8020 he uses? I think its size 10? trying to figure out as I would like to beg some roll nuts to use so I may create some attachment points from the rack itself. I messaged him but haven't been able to get a response. Thanks!
Brian recommended Tnutz.com
10 series hardware
Works great. Quite a few options. View attachment 2698536
ProSpeed doesnt use a rubber seal... and as another member mentioned, it doesn't need it~Can I ask if it's possible to NOT have to use the rubber type perimeter stuff against the paint? On the front fairing.
Experiencing heavy RainFall in N. Cali this week and noticed a leak on my passenger side Headliner. I'm assuming it is due to my new roof rack install. I was sure to use plenty of waterproof Silicone before mounting my Prospeed. Will I have to dismount my Roof Rack to reapply more Silicone? Any help is greatly appreciated.Made up some grab handles that work with the rack.
you should not have to disassemble the whole rack just back out the bolts on the passenger side and reapply silicone to the threads etc. .Experiencing heavy RainFall in N. Cali this week and noticed a leak on my passenger side Headliner. I'm assuming it is due to my new roof rack install. I was sure to use plenty of waterproof Silicone before mounting my Prospeed. Will I have to dismount my Roof Rack to reapply more Silicone? Any help is greatly appreciated.
Thank you for the prompt response. Did not mean to quote your response.you should not have to disassemble the whole rack just back out the bolts on the passenger side and reapply silicone to the threads etc. .
Went with this. So far so good.I use 3m ultra pro body sealer, never an issue with leaks if applied properly. If I’m not mistaken it’s also in the factory manual. It’s also recommended here:
Remove or Install Your Factory Roof Rack
Article by: RobRed Applicable Models: 1998 - 2007 / 100 Series Land Cruiser or Lx 470 Removal: 1. Remove the four corner Support Covers by grastlcfaq.com
