proper angle grinder disk for aluminum ?
colorado
Use the traditional cutting disk "stone impregnated in fiberglass?" disk for cutting steel stock, I find its slow for aluminum. Is there a better disk for cutting aluminum stock? I am cutting 3/16 inch thick aluminum.
I also learned long ago, to get a saw for the proper metal thickness, there must be at least two teeth of the blade resting on the metal cross section at anyone time.
I will be probebly shopping for a angle grinder cut off saw for aluminum.
I find surfboard wax on a small tooth wood cutting blade works well....their is also blades available that are designed for aluminium to fit angle grinders.
