Project LTD GX
As usual Dan is correct. Went by the Yota ship and got part #'s and prices. Sensor part # 89542-04020 and Wire Skid - 89516-60070. Then called Lexus to crossreference.:p
Hit me up next time. I have catalogs for Lexus and Toyota and I'm sure I can save you some $$.
I think maybe you missed my last post since it was the last one on the last page...
To be honest I am surprised you were even able to fit 285's on there with your running boards on. I had to remove mine to even get my 285's on there without rubbing.
LOL... My little lady gripes every time she has to hop into that thing and yells at me when she has to drive through the carpool with it and my 8 and 7 year olds have to be lifted in by the attendant. :)
LTD - do you have your front coils cranked very much? For some reason yours doesn't look as lifted as much as some the other GX's. Could be an optical illusion with the blue paint. ???
Sorry Bonner, must have missed. Front coils are Ironman and did put the spacers in. Might just be the camera angle. It does ride rough with the rear bags inflated. I hear ya on the passengers. :)
Got a picture of the coil overs before you put them on?
Do they have a threaded area for the ring to adjust up and down like the Icons?
OME and Ironman lift
Here are some photos I took before installing the lift. OME has black springs Ironman is yellow. These are fronts only.
These are my measurements (Ground to wheel well - center of tire) before and after the lift. Lexwoody's OME lift were amazingly identical to mine. Would be interested to know how the Ironman compares.
There was one other guy at 120 that has a Overland Warehouse lift but couldn't ever get him to take measurements.
Measurements before lift:
Normal setting - 35 1/8"
High setting - 36 1/2"
Measurements after lift:
Normal - 36 1/8"
High - 37 1/2"
Normal - 36 1/8"
High - 37 1/2"
If I'm doing it right, just @ 38" to the bottom of the flare....:hhmm:
Need to get Dan's height before and after too. He just did a similar lift.
Mine is exactly like Dan's. I called ACC and they ordered the exact setup. Only thing is I just trcked my rear airbags instead of fabbing spring perches and such. This is my daily driver, and I will get to the rear springs one day......
You need to straighten your wheel/tire - as having it cocked like that will make a difference.
Also - my measurement is for the rear of the vehicle.
I matched my rear bags Normal setting to exactly to my front measurements.
That means my front and rears are 36 1/8" all the way around in the normal setting.
My rear lifts to 37 1/2" in the HIGH position but the front will always stay at 36 1/8"
