Project Hope - 1959 FST FJ25
Simpson and I 25ed the 25 a little more. Went back to a generator to fix the charging issues
1962 wiring diagram for reference ;)
Can't believe you don't keep that beauty covered. I've gone to great lengths over the years to keep my cruisers covered, Running, non running, desert or forest. It did look like a fun drive something we haven't been able to do this winter in N. AZ.:crybaby: I do think it's ironic that a couple of early soft tops in CO have canvas without complete bows and in AZ we have bows with no canvas.:bang:
25ed the 25 a little more today. New shocks have been ordered as well as a set of OEM spring bushings.
To the parts horde!
Both sides were chamfered to give as much surface area and penetration to the weld.
The driver's shock tower needed a little help as well. Replaced the bolt with the OEM shock mount parts.
Simpson and I went to the hardware store and sourced 9.5mm stainless steel rod to replace the hood pins. I tried to weld the hood shut but luckily he pointed out I couldn't weld both sides of the pin :oops:
There is a copper washer between the two to keep everything operating smoothly. The cool part is that was one of the biggest rattles on the 25. I added some weather stripping to the tool box lid to silence the only other rattle she had.
JIS bolts that are really close (ACE Hardware) next to what I believe to be stock.
Cut on the diagonal so the tread parallels the outside edge.
I had to favorite that video! The :princess: and I cracked up at the big kid at the end of that top down snow drive.
How much vinyl did you buy for one set?
28" x 20" is the minimum to cut out one set diagonally. Most of the waste is the first cut though.
