Boy...such a simple task sure is kicking my ass. It's my main transportation/daily driver.
Original problem was a leaking drivers side, frame to axle hose. I got home safely, Thank You God, and I ordered Slee's complete set of lines, figuring that if that one went, the others are sure to follow.
So for now...I'm just trying to get this one dang line replaced at least and have it leak free but it's not working well for me.
The flare nut at the top stripped even with a flare nut wrench so I had to use a small vice grip plyers. Got old hose off and put the new Slee hose in place. The top fittings worked ok but the axle line goes into a splitter box thing. It keeps leaking there at the axle fitting. I've taken it off about three times, finally did it again with another line to see if that was the problem, nope...it leaked as well at the axle.
I realize that I need to replace the hard line at the frame with a new flare nut. I haven't figured out where this hard line runs and how to disconnect it yet but the question I really need help with is what to do at the axle end? It leaked when I tightened it up so I tightened it up a little more. Still leaked, so a little more, etc. I even used a tiny bit of white teflon pipe dope on the threads only on the sides like I would when doing a gas pipe. I used to be a plumber. I know not to get it on the end flare connection and also know that it shouldn't need it at all.
I'm almost at the point of calling Toyota and ordering new factory lines but even then, I don't know if the axle leak is caused by the fitting there inside the box splitter or why it's leaking there. If the local Toyota house had a factory hose, I would grab one of those and try it.
Suggestions please.
Thanks for your help.
Suggestions please.
