Problem with the Fan Relay, suggestions.
Rogers, Arkansas
I recently replaced the fan relay for the high setting. After about an hour the high setting simply stopped working again. None of the fuses are blown in the panel. Suggestions?
Possibly overloading of the heater relay? I'm guessing at this point. Also in the driver's kick panel. Give that guy a wiggle and make sure the connections are good. If still no go...
Strike that. Without the heater relay you would have no fan operation.
Time to sub-divide the circuit.
Remove the 10amp A/C fuse from the fuse panel by the driver's left knee. This will kill A/C operation, but still allow the fan to operate normally.
See if this has any effect.
Possible bad grounds or bad relay contacts or many other things. Has this truck ever gotten wet on the inside?
