After more tests, Here is what I found for the benefit of some other poor SBC user. Got the rig started, idled beautifully, Plugged vac. adv. port, set timing to 9*BTDC. All fine with the world, idle around 800. Rev engine, so far so good, run it up to 3000, observe advance, all looks o.k., let off throttle, promptly dies.....Cannot restart. Notice backfiring through the carb??? Indicates timing off, and me thinks that is odd, I just set it. After much fussing, get it started again, poor rough idle, check timing, now is sitting at about 7* After TDC???? Will not rev at all, and dies. More fussing, it lights, and idles semi-o.k. Check timing, now at around 0*. What the heck? Shut it down, remove cap, check rotor springs and advance weights. All appear normal... Next thing to check is timing chain slack. Can rotate the crank almost 15* before the rotor starts to move!!! Rotate crank backwards, and this time it is almost 20* before it moves!!! Holy $%^^ batman! I think we found the culprit..a stretched timing chain. Not 100% on this yet, but am pulling everything apart now. Anybody know how much a timing chain is allowed to rotate before effecting the cam?
